Per documentation, Insights for ArcGIS required base ArcGIS Enterprise Deployment with web adaptors installed for portal & server .
Required base ArcGIS Enterprise deployment
I don’t have web adaptor for the federated server as it's not required for the federation per documentation, but to install Insights, I will need to install the web adaptor for the federated server. I have services published to the hosted server.
ESRI doesn’t recommend to unfederated the server. I would like to know if I’m able to install web adapter for the federated server and use ArcGIS Online assistant to rename the services published to the hosted server? Any recommendation how I should proceed in this case?
