I am trying to add a new map to my Pro project (Pro 2.4.1) via c# and it is not working. My code looks like this:
var map = MapFactory.Instance.CreateMap("New Map", basemap: Basemap.None);
It creates the map object fine (I can access it via c# and add layers to it and save it as a map file), but it does not add the map to the project to be used there.
In the documentation here
ProConcepts Map Authoring · Esri/arcgis-pro-sdk Wiki · GitHub
It says:
Methods such as MapFactory.Instance.CreateMap() add the newly created map into the current project. You do not need to write additional code for adding a map to a project.
Is there anything else I can try to get this map addes to my project?
