I'm trying to create a function that leverages the auto increment function which is provided as a field calculator example in ArcGIS Pro's Calculate Field Python examples. The auto increment function is pretty straight-forward however, I'm looking to increment based on the attributes of another field. I've attached an example of the desired output. Below I've provided a snippet of the code where I've attempted to create a function that does what I've described but it doesn't seem to be working and I'm probably missing some important information about how field calculator works with tables. In the autoincrement function, you set the initial value to 0. But in an attempt to keep my function generic, I want to set the initial value to whatever is passed
