I'm trying to use an edit operation to populate attributes of a newly added field in a feature class. But the edit operation fails with the following message: "Edit operation failed. The data is currently locked by another user and cannot be saved"
My workflow is as follows:
- Create new feature class using existing feature class as template (using GP) - success
- Copy selected features in template feature class to the new feature class (using GP) - success
- Create a new field in feature class (using GP) - success
- Try to populate the new field (using this example) - error
What's locking the data? It's certainly not another user. I'm the only user. The gdb workspace is a temp folder in my user appdata dir.
The data isn't on the map or open anywhere else.
