I am using the filter widget in my web map but there are a few tweaks I would like to make.
One thing I noticed while using the filter widget is, if you uncheck the check mark in the top right corner of the widget after you filter, your map features that you filtered will go away but your inputs in the widget itself do not clear. This will potentially cause confusion with the end users because they will have to go and delete each input if they're interested in doing another filter search. Is there a way I can customize the filter widget so that when the check mark is unchecked it will not only clear the filtered map features but
