Download both the latest eSearch & WAB 2.7, copied the eSearch folder to C:\GIS API\WebAppBuilder2.7\WebAppBuilderForArcGIS\client\stemapp\widgets and went to create a new app and i added the eSearch Widget and i was able to set it up but when i went to test it I go "Create Widget Error"Widget/eSearch/Widget". I tried the WAB 2.7 in firefox and Chrome and i get the same error. I did not edit anything in the WAB 2.7 or the eSearch folders.
Anyone else having this issue?
In Chromes browser console i get.
main.js?wab_dv=2.7:199 jimu.js init...
ConfigManager.js?wab_dv=2.7:136 Load Config: 887.1259765625ms
(index):1 Failed to load https://mapcase.deq.idaho.gov/arcgis/rest/info?f=json: The 'Access-Control-Allow-Origin' header contains multiple values 'http://******:3344, *', but only one is allowed. Origin 'http://******:3344' is therefore not allowed access.
MapManager.js?wab_dv=2.7:214 Load Map: 3382.7138671875ms
WidgetManager.js?wab_dv=2.7:114 widget [themes/LaunchpadTheme/widgets/Header/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/ZoomSlider/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/Coordinate/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/Scalebar/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/MyLocation/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/HomeButton/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/OverviewMap/Widget] created.
Widget.js?wab_dv=2.7:46 LocateButton::navigator.geolocation requires a secure origin.
WidgetManager.js?wab_dv=2.7:114 widget [themes/LaunchpadTheme/widgets/AnchorBarController/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/Search/Widget] created.
AbsolutePositionLayoutManager.js?wab_dv=2.7:106 Load widgetOnScreen: 1238.56005859375ms
PanelManager.js?wab_dv=2.7:83 panel [_33_panel] created.
WidgetManager.js?wab_dv=2.7:116 create [widgets/eSearch/Widget] error:TypeError: Cannot read property 'length' of null
at Function.n.fromHex.b.colorFromHex [as fromHex] (https://jsdev.arcgis.com/3.23/init.js:208:110)
at Object._addCustomStyle (http://******:3344/webappbuilder/apps/2/widgets/eSearch/Widget.js?wab_dv=2.7:3913:30)
at Object.postCreate (http://******:3344/webappbuilder/apps/2/widgets/eSearch/Widget.js?wab_dv=2.7:183:14)
at Object.create (https://jsdev.arcgis.com/3.23/init.js:355:366)
at Object.postscript (https://jsdev.arcgis.com/3.23/init.js:354:104)
at new <anonymous>
