Hello everyone,
Looking for help with adding data (Feature Class, Layer File and Web Service) using Combo box C# addin module for ArcPro SDK for .Net through Visual Studio. I have a code created, but it does not do what I want. Instead of adding a specific layer upon selection; it adds all the layers listed in the OnSelectionChange part. How do I modify the OnSelection code, so only specific layer that is selected in the combo box as an item would be added to the active map. For this example I'm using web services. Thank you
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>Collections<SPAN class="punctuation token">.</SPAN>Generic<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>Collections<SPAN class="punctuation token">.</SPAN>ObjectModel<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>ComponentModel<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>Linq<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>Text<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>Threading<SPAN class="punctuation token">.</SPAN>Tasks<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Core<SPAN class="punctuation token">.</SPAN>CIM<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Core<SPAN class="punctuation token">.</SPAN>Data<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Core<SPAN class="punctuation token">.</SPAN>Geometry<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Catalog<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Core<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Editing<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Extensions<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">.</SPAN>Contracts<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">.</SPAN>Dialogs<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">.</SPAN>Threading<SPAN class="punctuation token">.</SPAN>Tasks<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Mapping<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">namespace</SPAN> Test
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">internal</SPAN> <SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">ComboBox1</SPAN> <SPAN class="punctuation token">:</SPAN> ComboBox
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">bool</SPAN> _isInitialized<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">public</SPAN> <SPAN class="token function">ComboBox1</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="token function">UpdateCombo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">UpdateCombo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// TODO – customize this method to populate the combobox with your desired items </SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>_isInitialized<SPAN class="punctuation token">)</SPAN>
SelectedItem <SPAN class="operator token">=</SPAN> ItemCollection<SPAN class="punctuation token">.</SPAN><SPAN class="token function">FirstOrDefault</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//set the default item in the comboBox</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>_isInitialized<SPAN class="punctuation token">)</SPAN>
<SPAN class="token function">Clear</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ComboBoxItem</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Item1"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ComboBoxItem</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Item2"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
_isInitialized <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
Enabled <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">protected</SPAN> <SPAN class="keyword token">override</SPAN> <SPAN class="keyword token">async</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">OnSelectionChange</SPAN><SPAN class="punctuation token">(</SPAN>ComboBoxItem item<SPAN class="punctuation token">)</SPAN>
ComboBoxItem Item1 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>item <SPAN class="operator token">==</SPAN> Item1<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> url <SPAN class="operator token">=</SPAN> <SPAN class="string token">@"https://maps.nj.gov/arcgis/rest/services/Basemap/Highlands_NJ/MapServer"</SPAN><SPAN class="punctuation token">;</SPAN>
Uri uri <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>url<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> LayerFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateLayer</SPAN><SPAN class="punctuation token">(</SPAN>uri<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
ComboBoxItem Item2 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>item <SPAN class="operator token">==</SPAN> Item2<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">string</SPAN> url <SPAN class="operator token">=</SPAN> <SPAN class="string token">@"https://maps.nj.gov/arcgis/rest/services/Basemap/AdminBound_NJ/MapServer"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
