I have following code:
<SPAN class="keyword token">var</SPAN> operation <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">EditOperation</SPAN>
<SPAN class="punctuation token">{</SPAN>
Name <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Test edit operation"</SPAN><SPAN class="punctuation token">,</SPAN>
ShowModalMessageAfterFailure <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
EditOperationType <SPAN class="operator token">=</SPAN> EditOperationType<SPAN class="punctuation token">.</SPAN>Long<SPAN class="punctuation token">,</SPAN>
CancelMessage <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
ProgressMessage <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
ShowProgressor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
operation<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Callback</SPAN><SPAN class="punctuation token">(</SPAN>context <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="comment token">// I never get here if fc is a feature class from SDE database</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
fc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
operation<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Execute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>If fc is a feature class from SDE database I never fall to callback's body. If feature class is from FGDB all is OK. What am I doing wrong?
I'm taking a feature class from Geodatabase returned by GDBProjectItem.GetDatastore.
