I have been working on refining my custom widget and would like it to function similarly to that of the Jewelry Box theme in that there is a side panel that can be minimized and maximized by a small tab.
For whatever reason the map shifts and takes my panel with it separating it from the sidebar? How do I anchor my panel to my sidebar? This is a custom theme I created for my project.
<SPAN class="token function">define</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'dojo/_base/declare'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'dijit/_TemplatedMixin'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'dojo/text!./Panel.html'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'dojo/topic'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'jimu/BaseWidgetPanel'</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>declare<SPAN class="punctuation token">,</SPAN> _TemplatedMixin<SPAN class="punctuation token">,</SPAN> template<SPAN class="punctuation token">,</SPAN> topic<SPAN class="punctuation token">,</SPAN> BaseWidgetPanel<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token function">declare</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>BaseWidgetPanel<SPAN class="punctuation token">,</SPAN> _TemplatedMixin<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
baseClass<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'jimu-panel jimu-border-panel'</SPAN><SPAN class="punctuation token">,</SPAN>
templateString<SPAN class="punctuation token">:</SPAN> template<SPAN class="punctuation token">,</SPAN>
postCreate<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN
