Custom Transformation only seem to work in the map view but the user cannot apply the custom transformation when exporting/copying the data 😞 In ArcMap the user is asked whether or not to use the coordinate system definition of the data frame when exporting and in this case the data gets transformed but unfortunately this doesn't seem to work in ArcGIS Pro.
Please also refer to:
https://community.esri.com/message/806443-custom-geographic-transformation-logic
I've attached the GTF-file which works in in the Map View but which cannot be used when exporting data. Only known in workaround is to go back and use ArcMap which is kind of frustrating when the rest of the workflow can be executed using Tasks, ModelBuilder and Python scripts in ArcGIS Pro.
