I want to create a lithology chart for every points (borehole) on map. I've tried using ArcGIS Pro's pops up chart, but there's a lot of problems and limitations? (Please advise if I am wrong, I will post the issue in another group)
Then, I turn to Related Table Charts widget as the data are to be published on ArcGIS Portal. But in the widget configuration, I can't select a table related to layer (See image). I thought maybe widget doesn't accept widget with non-numeric fields (indicated below), so I deleted all the non-numeric fields. But still the same, can't select a table.
