I copied the setting page from the Demo widget and I try to adjust it to suit my widget. My config.json contains the configText variable and several others as well. When I open the config window for my widget in app1, I see only the config.json contents, not UI as for other widgets. I can edit the JSON code freely.
So far I found no way to use any more complex debugging options or even how to debug the settings.js through FireBug (I can debug Widget.js, which works), so I can't confirm that the setting code is not even loaded, but it doesn't seem to respond to changes in my
