Hello!
I downloaded a geodatabase with all countries, included independent regions with their own borders. For the purpose of my work, I need to keep Antartica on the map. Initially, I used the GCS_WGS_1984 (source), then I decided to use the projected coordinate system world WGS 1984 Web Mercator. However I don't like the result (document attached), mainly because Antartica is shaped like a rectangle. How can I improve this visualization?
In reality I don't like WGS 1984 Web Marcator also because Greenland results bigger than South America, do you have alternatives?
Thank you
