I implemented a PRO SDK SearchTextBox however it works pretty slow. I read from a CSV file and create an object type Observable Collection and dump that into SuggestionSource then filter the results as SearchBox text change. Do you have any idea what I am doing wrong?
XAML :
<!-- Inserting inside user control -->
xmlns:controls="clr-namespace:ArcGIS.Desktop.Framework.Controls;assembly=ArcGIS.Desktop.Framework"
<!-- Inserting inside a stack panel-->
<controls:SearchTextBox x:Name="SearchLayersBox" Height="23" Margin="5,5,10,10" VerticalAlignment="Top" InfoText="Search" SearchMode="Auto" ShowHistory="True" Search="SearchTextBox_Search" Initialized="SearchLayersBox_Initialized" TextChanged="SearchLayersBox_TextChanged" SuggestionListMax="15" />
C#
public void LayersListSearchBox()
LayerDict.Clear();
DataListBoxSource.Clear();
var path = @\\nrdsmnt6\mine maps\DMP_Database\Layer_Properties_spc_CSV.csv;
using (TextFieldParser csvParser = new TextFieldParser(path))
csvParser.SetDelimiters(new string[] { "*%&" });
csvParser.HasFieldsEnclosedInQuotes = false;
//Skip the row with the column names
csvParser.ReadLine();
while (!csvParser.EndOfData)
string[] fields = csvParser.ReadFields();
string LayerDisplayName = fields[3].Substring(1);
SearchSuggestCollection.Add(LayerDisplayName);
SearchLayersBox.SuggestionSource = SearchSuggestCollection;
private void SearchLayersBox_TextChanged(object sender, TextChangedEventArgs e)
string searchString = SearchLayersBox.Text;
ObservableCollection<object> filteredCollection = new ObservableCollection<object>(from objectL in SearchSuggestCollection where objectL.ToString().Contains(searchString) select objectL);
SearchLayersBox.SuggestionSource = filteredCollection;
private void SearchLayersBox_Initialized(object sender, EventArgs e)
LayersListSearchBox();
