I'm working in WAB 2.12. I'm not sure why this wouldn't work, and I was hoping someone could point me in the right direction. I want a dialog box upon opening the widget, and I'm placing the button markup for the dialog box in widget.html, but i thought you were supposed to be able to reference the HTML via the data-dojo-attach-point. When my dialog box opens, it's empty. Do you know what I'm missing?
Widget.html
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">data-dojo-attach-point</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>myTemp<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">data-dojo-type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>dijit/Dialog<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">title</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>My Title<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>button</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>btn<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">data-dojo-type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>dijit/form/Button<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>button<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>Button1 <SPAN class="token tag"><SPAN class="token
