Hi, im working with the AppStudio for ArcGIS and I noticed that the memory is not released properly in many applications made by Esri like Palm Spring Map Tour, Map Tour, Survey 123 (when i use de barcode scanner)
BarcodeDecoder:
I'm developing an application where i have to use a barcode scanner and after some failed barcode scanning the memory usage increase too much.
As i was having troubles with it, I downloaded and used exactly the same code of the survey 123 to decode barcodes and I still having the same behaviour.
The same happens with the barcode scanner of the AppStudio Player.
Map:
AppStudio for ArcGIS / Map memory leaks
I attached some videos
Any help will be greatly appreciated.
