I like to merge several polygon records into one with boundary preserved, but not dissolved using sql statements on sql server 2016. So I consider to use multipolygon.
Fro the link, http://desktop.arcgis.com/en/arcmap/latest/manage-data/gdbs-in-sql-server/sqlserver-spatial-types-and-arcgis.htm
Under the section "Register an existing spatial table with the geodatabase", it is stated that sql server supports mulitipolygon. But it does not state if arcgis server supports it or not, also not give an example how to make one from a list of records. And I searched out on the internet, no example could be found for how to use multipolygon.
So, is multipolygon supported on arcgis server by using map service, and any example on how to make one multipolygon record from several records of one table?
