I have a WAB app with some modified code. I've been running this code in WAB V2.8 for awhile without issue and need to upgrade to V2.13. This code has failed in V2.13
This code allows the user to click on the map, coordinates are collected, popup is shown with URL link to Survey123. Right now it does everything but show the popup.
I will include the code below which sits in server->apps->2->jimu.js->MapManager.js-> in the publish map event function:
_publishMapEvent<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
topic<SPAN class="punctuation token">.</SPAN><SPAN class="token function">subscribe</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'toggleChanged'</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>visible<SPAN class="punctuation token">,</SPAN> layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>visible <SPAN class="operator token">&&</SPAN> layer<SPAN class="punctuation token">.</SPAN>title<SPAN class="operator token">==</SPAN><SPAN class="string token">'t_Main_Floor'</SPAN><SPAN class="operator token">||</SPAN>layer<SPAN class="punctuation token">.</SPAN>title<SPAN class="operator token">==</SPAN><SPAN class="string token">'t_Mezz_Floor'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
