Learning ArcGIS Pro (2.0), as well as the new API. I have been able to get Jupyter Notebooks going and run the sample code from index | ArcGIS for Developers . I wanted to use PyCharm as an alternative IDE to Jupyter and I have it also running. I was able to run this section of code (from the NYC Cab demonstration notebook ) in PyCharm successfully, as indicated that it can back with a code of 0 .
import arcgis
from arcgis.gis import GIS
ago_gis = GIS() # Connect to ArcGIS Online as an anonymous user
search_subset = ago_gis.content.search("NYC_taxi_subset", item_type = "Feature Layer")
subset_item = search_subset[0]
subset_item
subset_map = ago_gis.map("New York, NY", zoomlevel=11)
subset_map
subset_map.add_layer(subset_item)
subset_feature_layer = subset_item.layers[0]
# query the attribute information. Limit to first 5 rows.
query_result = subset_feature_layer.query(where = 'OBJECTID < 5',
out_fields = "*",
returnGeometry = False)
att_data_frame = query_result.df # get as a Pandas dataframe
att_data_frameHowever none of the maps were displayed nor the table, which gets loaded into the dataframe. I have tried this code in a new Jupyter Notebook and the maps don't get displayed but the table does. I'm wondering why the differences between the three IDE locations, in terms of the varying output.
Eric
