I have a large feature layer that is constantly updated and resides on AGOL. The feature layer contains over 77,000 parcels. My program worked fine when testing it on a smaller data set but now I am getting a time out error. I was able to modify the api, if a 504 error occurred and while I can successfully delete all the records, but I cannot add new records.
My code and the error message are posted below.
req = requests.get(siteurl,timeout=1000 )
if req.status_code == 200:
logging.info("success")
target = GIS(siteurl, uname, pword)
#Search for file by title owner and type
newquery = ("title: " + '"' + filetitle + '"' + " AND owner: " + '"' + fileowner + '"')
parcelsearch = target.content.search(query = (newquery), item_type = 'Feature Layer Collection', max_items = 1000)
for layer in parcelsearch:
print(layer.title)
feature_layer = parcelsearch[0]
epoch_crt = datetime.datetime.fromtimestamp(feature_layer.created/1000.0).strftime('%d/%m/%Y')
crt_epoch = datetime.datetime.strptime(epoch_crt, '%d/%m/%Y').strftime('%m/%d/%Y').replace('X0','X').replace('X','')
epoch_mod = datetime.datetime.fromtimestamp(feature_layer.modified/1000.0).strftime('%d/%m/%Y')
mod_epoch = datetime.datetime.strptime(epoch_mod, '%d/%m/%Y').strftime('%m/%d/%Y').replace('X0','X').replace('X','')
logging.info("Url of feature layer %s Feature Layer id %s Item created on %s Item modified on %s" % (feature_layer.url, feature_layer.id, crt_epoch, mod_epoch))
flc = FeatureLayerCollection(feature_layer.url, target)
flc_ly1=flc.layers[0]
f1_list = feature_layer.layers
#delete the file and add records
parcel = f1_list[0]
logging.info("Total number of records before delete %s " %parcel.query(return_count_only=True)) #get the total number of features
if(parcel.delete_features(where="objectid > 0")):
logging.info("Total number of records after delete %s " %parcel.query(return_count_only=True)) #get the total number of features
newfile = FeatureLayerCollection.fromitem(feature_layer)
uploadfile = ("r" + "'" + filenm + "'")
print(uploadfile)
#spatialDataFrame = fs.SpatialDataFrame(data=df, geometry=listGeometries)
sdf1 = SpatialDataFrame.from_featureclass(r'C:\name of geodatabase file)
fs = sdf1.to_featureset()
parcel.edit_features(adds=fs)
error message:
File "Updateparcels_agol.py", line 119, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\layer.py", line 1121, in edit_features
return self._con.post(path=edit_url, postdata=params, token=self._token)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\connection.py", line 1104, in post
resp = opener.open(url, data=encoded_postdata.encode())
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 526, in open
response = self._open(req, data)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 544, in _open
'_open', req)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 504, in _call_chain
result = func(*args)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 1361, in https_open
context=self._context, check_hostname=self._check_hostname)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 1320, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [WinError 10054] An existing connection was forcibly closed by the remote host>#
