Running following code I am able to get JSON result back from a Geometric Network Service on ArcGIS Server but I am having trouble to add the Geometries (Returened graphic) to the graphicsLayerTraceNetworkEdges can you please let me know what I am doing wrong here?
As you can see I already tried both
<SPAN class="keyword token">var</SPAN> graphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">esri<SPAN class="punctuation token">.</SPAN>Graphic</SPAN><SPAN class="punctuation token">(</SPAN>featureSet<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
and
<SPAN class="keyword token">var</SPAN> graphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">esri<SPAN class="punctuation token">.</SPAN>Graphic</SPAN><SPAN class="punctuation token">(</SPAN>featureSet<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> symbolTraceNetworkEdges<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
but neither of the adding any graphics to the graphicsLayerTraceNetworkEdges
Here is the code I am running
<SPAN class="keyword token">var</SPAN> symbolTraceNetworkEdges <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">esri<SPAN class="punctuation token">.</SPAN>symbol<SPAN class="punctuation token">.</SPAN>SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>esri<SPAN class="punctuation token">.</SPAN>symbol<SPAN class="punctuation token">.</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">dojo<SPAN class="punctuation token">.</SPAN>Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> graphicsLayerTraceNetworkEdges <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">esri<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">.</SPAN>GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> rendererTraceNetworkEdges <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">esri<SPAN class="punctuation token">.</SPAN>renderer<SPAN class="punctuation token">.</SPAN>SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN>symbolTraceNetworkEdges<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
graphicsLayerTraceNetworkEdges<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>rendererTraceNetworkEdges<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
graphicsLayerTraceNetworkEdges<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setInfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN>infoTemplate<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>graphicsLayerTraceNetworkEdges<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">solve</SPAN><SPAN class="punctuation token">(</SPAN>traceSolverType<SPAN class="punctuation token">,</SPAN> params<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
esri<SPAN class="punctuation token">.</SPAN><SPAN class="token function">request</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN>agsConfig<SPAN class="punctuation token">.</SPAN><SPAN class="token function">urlGNUtility</SPAN><SPAN class="punctuation token">(</SPAN>agsConfig<SPAN class="punctuation token">.</SPAN>operationalLayers<SPAN class="punctuation token">.</SPAN>GNLayer<SPAN class="punctuation token">,</SPAN> gn <SPAN class="comment token">/* id layer from soe*/</SPAN><SPAN class="punctuation token">,</SPAN> traceSolverType <SPAN class="comment token">/*name of operation SOE */</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN>params<SPAN class="punctuation token">,</SPAN>
callbackParamName<SPAN class="punctuation token">:</SPAN><SPAN class="string token">"callback"</SPAN><SPAN class="punctuation token">,</SPAN>
load<SPAN class="punctuation token">:</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
graphicsLayerTraceNetworkEdges<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clear</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> resultFeatures <SPAN class="operator token">=</SPAN> result<SPAN class="punctuation token">.</SPAN>edges<SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>resultFeatures<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> j <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> jl <SPAN class="operator token">=</SPAN> resultFeatures<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> j <SPAN class="operator token"><</SPAN> jl<SPAN class="punctuation token">;</SPAN> j<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> featureSet <SPAN class="operator token">=</SPAN> resultFeatures<SPAN class="punctuation token">[</SPAN>j<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> il <SPAN class="operator token">=</SPAN> featureSet<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> il<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//var graphic = new esri.Graphic(featureSet<I>); </I></SPAN>
graphicsLayerTraceNetworkEdges<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
