I need to generate the weighted centroid point using Mean Center tool. But it failed with the following error:
arcpy.MeanCenter_stats('Zip5_all_air', r'C:\Users\nanamzn\Documents\ArcGIS\Default.gdb\Zip3_MeanCenter', 'PackageNumber', '#', '#')
Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> File "c:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\stats.py", line 1231, in MeanCenter raise e ExecuteError: Traceback (most recent call last): File "c:\program files (x86)\arcgis\desktop10.5\ArcToolbox\Scripts\MeanCenter.py", line 25, in <module> import SSUtilities as UTILS File "c:\program files (x86)\arcgis\desktop10.5\ArcToolbox\Scripts\SSUtilities.py", line 29, in <module> import matplotlib.path as PATH File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 129, in <module> from matplotlib.externals.six.moves.urllib.request import urlopen File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\externals\six.py", line 90, in __get__ result = self._resolve() File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\externals\six.py", line 158, in _resolve module = _import_module(self.mod) File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\externals\six.py", line 80, in _import_module __import__(name) File "C:\Anaconda2\Lib\urllib2.py", line 94, in <module> import httplib File "C:\Anaconda2\Lib\httplib.py", line 72, in <module> import socket File "C:\Anaconda2\Lib\socket.py", line 47, in <module> import _socket ImportError: DLL load failed: %1 is not a valid Win32 application. Failed to execute (MeanCenter).
I uninstalled Anaconda2 from my machine and rerun the tool. It failed again with different error. May I ask how to fix the problem?
>>> arcpy.MeanCenter_stats('Zip5_all_air', r'C:\Users\nanamzn\Documents\ArcGIS\Default.gdb\Zip3_MeanCenter1', 'PackageNumber', '#', '#')
Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> File "c:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\stats.py", line 1231, in MeanCenter raise e ExecuteError: Traceback (most recent call last): File "c:\program files (x86)\arcgis\desktop10.5\ArcToolbox\Scripts\MeanCenter.py", line 25, in <module> import SSUtilities as UTILS File "c:\program files (x86)\arcgis\desktop10.5\ArcToolbox\Scripts\SSUtilities.py", line 29, in <module> import matplotlib.path as PATH File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 1138, in <module> rcParams = rc_params() File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 971, in rc_params fname = matplotlib_fname() File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 800, in matplotlib_fname configdir = _get_configdir() File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 655, in _get_configdir return _get_config_or_cache_dir(_get_xdg_config_dir()) File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 580, in _get_xdg_config_dir path = get_home() File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 320, in wrapper ret = func(*args, **kwargs) File "C:\Python27\ArcGIS10.5\lib\site-packages\matplotlib\__init__.py", line 522, in _get_home path = os.path.expanduser(b"~").decode(sys.getfilesystemencoding()) LookupError: unknown encoding: mbcs Failed to execute (MeanCenter).
Thanks a lot!
Anna
