Hi,How to get the coordinates of a symbol (point)?My problem that 's I can not get the center of the Graphic.Here is my function:private bool isHandler; private void FeatureLayer_MouseLeftButtonDown(object sender, GraphicMouseButtonEventArgs args) { if (args.Graphic != null) { this.isHandler = true; Point screenPoint = args.GetPosition(Map); MapPoint mapPoint = Map.ScreenToMap(screenPoint); if (Map.WrapAroundIsActive) { mapPoint = ESRI.ArcGIS.Client.Geometry.Geometry.NormalizeCentralMeridian(mapPoint) as MapPoint; CoordPointX.Text = Math.Round(mapPoint.X, 4).ToString(); CoordPointY.Text = Math.Round(mapPoint.Y, 4).ToString(); } args.Graphic.MouseMove += (s, e) => { if (this.isHandler == true) { Point screenPointMove = e.GetPosition(Map); MapPoint mapPointMove = Map.ScreenToMap(screenPointMove); if (Map.WrapAroundIsActive) { mapPointMove = ESRI.ArcGIS.Client.Geometry.Geometry.NormalizeCentralMeridian(mapPointMove) as MapPoint; CoordPointX.Text = Math.Round(mapPointMove.X, 4).ToString(); CoordPointY.Text = Math.Round(mapPointMove.Y, 4).ToString(); } } }; args.Graphic.MouseLeftButtonUp += (u, k) => { Point screenPointUp = k.GetPosition(Map); this.isHandler = false; MapPoint mapPointUp = Map.ScreenToMap(screenPointUp); if (Map.WrapAroundIsActive) { mapPointUp = ESRI.ArcGIS.Client.Geometry.Geometry.NormalizeCentralMeridian(mapPointUp) as MapPoint; CoordPointX.Text = Math.Round(mapPointUp.X, 4).ToString(); CoordPointY.Text = Math.Round(mapPointUp.Y, 4).ToString(); } }; } }
