hi, i'm trying to execute this python script to establish aan sql query and the result is "Execute SQL Statement: select [objectid) from [P10TN_SIG.DBO.BCBATIMS] where [shape.area] > 200"<type 'exceptions.Exception'> 'ascii' codec can't encode character u'\ue51c' in position 52: ordinal not in range(128)please help
>>> try:
... env.workspace = (r"c:\connectionfiles\con21.sde")
... sdeConn = arcpy.ArcSDESQLExecute(r"c:\connectionfiles\con21.sde")
... SQLStatement = ("select [objectid) from [P10TN_SIG.DBO.BCBATIMS] where [shape.area] > 200")
... SQLStatementList = SQLStatement.split(";")
... print "\n"
... # For each SQL statement passed in, execute it.
... for sql in SQLStatementList:
... print "Execute SQL Statement: " + sql
... try :
... #Pass the SQL statement to the database.
... sdeReturn = sdeConn.execute(sql)
... except Exception, ErrorDesc:
... print ErrorDesc
... sdeReturn = False
... #If the return value is a list (a list of lists), display each list as a row from the
... #table being queried.
... if isinstance(sdeReturn, list):
... print "Number of rows returned by query: " + len(sdeReturn), "rows"
... for row in sdeReturn:
... print row
... print "\n"
... else:
... #If the return value was not a list, the statement was most likely a DDL statment.
... #Check its status.
... if sdeReturn == True:
... print "SQL statement: " + sql + " ran sucessfully."
... print "\n"
... else :
... print "SQL statement: " + sql + " FAILED."
... print "\n"
... print Exception, ErrorDesc
... except:
... print "Problem executing SQL."
