Dear all,
I am using arcmap 9.3 with VB.Net. I need to get the adjacent building so i am using the Itopological operator for get the building. i am doing following coding but i am not complete the coding i have struggle please any one help me for complete the coding.
Sub exampleITopologicalOperator_Buffer(ByVal x As Double, ByVal y As Double)
Dim featureCursor As IFeatureCursor
Dim ptc As ESRI.ArcGIS.Geometry.IPointCollection, i As Long, pa As ESRI.ArcGIS.Geometry.IArea, ptopo As ESRI.ArcGIS.Geometry.ITopologicalOperator
ptc = New ESRI.ArcGIS.Geometry.Polygon
Dim pt(4) As ESRI.ArcGIS.Geometry.IPoint, poutPoly As ESRI.ArcGIS.Geometry.IPolygon
'The spatial reference should be set here using IGeometry::SpatialReference (Code skipped here) 344011.132111 6300045.490245
For i = 0 To 4
pt(i) = New ESRI.ArcGIS.Geometry.Point
pt(0).PutCoords(x + 0.5, y)
pt(1).PutCoords(x, y + 0.5)
pt(2).PutCoords(x - 0.5, y)
pt(3).PutCoords(x, y - 0.5)
pt(4).PutCoords(x + 0.5, y)
Dim geometryBride As ESRI.ArcGIS.Geometry.IGeometryBridge
geometryBride = New ESRI.ArcGIS.Geometry.GeometryEnvironmentClass()
geometryBride.AddPoints(ptc, pt)
pa = ptc
ptopo = ptc
poutPoly = ptopo.Buffer(-1) 'inside buffer
pa = poutPoly
Dim SpatialFilter As ISpatialFilter
SpatialFilter.Geometry = poutPoly
SpatialFilter.SpatialRel = ESRI.ArcGIS.Geodatabase.esriSpatialRelEnum.esriSpatialRelOverlaps
End Sub
