I am having difficulty accessing a control property on another form. I followied some instructions online that suggested using Get to accesscontrol properties on other forms. For the most part it seems to work but the same problem occurs in that I am unable to retrieve the numberof columns from an already existing and populated DataGridView (dgvDatabase) on the already existing form frmXLStoDBF. The code below is justa subset and only includes the relevant subroutines to this problem.This program consists of 3 class modules, 2 of which are form classes.Execution Order1.) btnXLStoDBF.OnClick() <--This executes properly and calls myfrmXLStoDBF.ReadXL()2.) myfrmXLStoDBF.ReadXL() <--This executes properly and populates the DataGridView control named frmXLStoDBF.dgvDatabase <--A button (btnFieldAttributes_Click is pressed to display the myfrmFieldAttributes.Show3.) btnFieldAttributes <--This executes properly 4.) btnGetHeadings_Click <--Gets to this routine but does not properly read the number of columns from frmXLStoDBF.dgvDataBasePublic Class btnXLStoDBF Inherits ESRI.ArcGIS.Desktop.AddIns.Button 'Inherits System.Windows.Forms.Form 'Inherits can appear only once within a Class statement and can only specifiy one class Public m_myfrmXLStoDBF As frmXLStoDBF Public ReadOnly Property myfrmXLStoDBF() As frmXLStoDBF Get If IsNothing(m_myfrmXLStoDBF) Then m_myfrmXLStoDBF = New frmXLStoDBF Return m_myfrmXLStoDBF End Get End Property Protected Overrides Sub OnClick() 'This is the main subroutine that is initiated upon clicking a button in ESRI ArcMap Addin Call myfrmXLStoDBF.ReadXL() End Sub End Class Public Class frmXLStoDBF 'THIS IS THE MAIN FORM CLASS - There are two Panel Controls, Two Button Controls, and a DataGridView named dgvDatabase Inherits System.Windows.Forms.Form Public ReadOnly Property myfrmFieldAttributes() As frmFieldAttributes Get If IsNothing(m_myfrmFieldAttributes) Then m_myfrmFieldAttributes = New frmFieldAttributes Return m_myfrmFieldAttributes End Get End Property Private Sub btnReadExcel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnReadExcel.Click Call ReadXL() End Sub Private Sub btnFieldAttributes_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnFieldAttributes.Click myfrmFieldAttributes.Show() End Sub Public Sub ReadXL() 'Blah do stuff here End Sub End Class Public Class frmFieldAttributes 'THIS IS THE SECOND FORM CLASS - There are two Panel Controls, 6 Button Controls, and a DataGridView named dgvFieldAttributes Inherits System.Windows.Forms.Form Public m_myfrmXLStoDBF As frmXLStoDBF Public ReadOnly Property myfrmXLStoDBF() As frmXLStoDBF Get If IsNothing(m_myfrmXLStoDBF) Then m_myfrmXLStoDBF = New frmXLStoDBF Return m_myfrmXLStoDBF End Get End Property Private Sub btnGetHeadings_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnGetHeadings.Click Call BlankAttributes() Dim ncol As Integer = myfrmXLStoDBF.dgvDataBase.ColumnCount - 1 '<--Problem occurs here. It returns 0 for ColumnCount: ncol = -1 Dim nrow As Integer = myfrmXLStoDBF.dgvDataBase.RowCount - 2 ReDim Headings(ncol) Dim row(4) For i = 0 To ncol Headings(i) = myfrmXLStoDBF.dgvDataBase.Columns(i).HeaderText row(0) = i row(1) = Headings(i) dgvFields.Rows.Add(row) Next i End Sub End Class
ThanksDan
