Hello, all.
I tried to run the webgisdr utility on a separate server from our primary Portal and got an error about the JAVA_HOME environment not being set. I checked the environment variables on our primary Portal and JAVA_HOME is not set there, but Java looks to be available from the Portal's install path ($install_dir\framework\runtime\jre).
We are setting up a disaster recovery configuration with primary and secondary Enterprise servers. I read on this resource that the webgisdr utility could be copied and run from a different server than the server installed with Portal.
+ https://enterprise.arcgis.com/en/portal/10.7/administer/windows/overview-disaster-recovery-replication.htm
Java is not installed on the server we would to use to run the utility. Is Java a requirement for using webgisdr?
Thanks in advance for any help you can provide. Best, Dixie.
