I am running through some tutorials and having an issuehttps://developers.arcgis.com/en/javascript/jstutorials/intro_agstemplate_amd.htmlI am trying to use the Web Map Id they said you can in the example and then the map vanishes. I dont know how to get another one I can use.I assume that the web map id is not working....what else can I be doing wrongIf you haven't created a web map yet, you can use 1a40fa5cc1ab4569b79f45444d728067 for testing.
require([ "esri/map", "esri/arcgis/utils", "dojo/domReady!" ], function(Map, arcgisUtils){ arcgisUtils.createMap("1a40fa5cc1ab4569b79f45444d728067", "mapDiv").then(function (response) { map = response.map; }); });
If I use this from the first example then the map shows up finemap = new Map("mapDiv", { center: [-77.4329, 37.5410], zoom: 6, basemap: "streets"
<script> var map; require(["esri/map", "esri/arcgis/utils", "esri/dijit/Legend", "dojo/domReady!" ], function(Map, arcgisUtils, Legend ) { arcgisUtils.createMap("1a40fa5cc1ab4569b79f45444d728067", "mapDiv").then(function (response) { map = response.map; var legend = new Legend({ map: map, layerInfos:(arcgisUtils.getLegendLayers(response)) }, "legendDiv"); legend.startup(); }); }); </script>
