Hi everyone,
I'm trying to define an expression for labeling parcel polygons in ArcMap. The feature class has 3 attributes of interest: CATEGORIA, NUM_CATASTRO, and PARCEL_SP. If CATEGORIA (integer field with subtypes defined) is not 0 (N/A), then label the polygon with the value in PARCEL_SP, otherwise label with NUM_CATASTRO. I'm not a programmer and I'm just starting with Python so I'm not sure what is missing. So far I have...
def FindLabel ( [CATEGORIA],[NUM_CATASTRO], [PARCEL_SP] ):
if [CATEGORIA] ==0:
return [PARCEL_SP]
else:
return [NUM_CATASTRO]
The issue is that I can see labels for NUM_CATASTRO where they should, but none for PARCEL_SP.
If I reverse the values...
if [CATEGORIA] ==0:
else:
return [PARCEL_SP]
it labels the PARCEL_SP where is supposed to but not the NUM_CATASTRO.
Same thing using the following statement...
if [CATEGORIA] !=0:
return [PARCEL_SP]
else:
Any help will be appreciated...
