As you can see below my tree symbol is hidden underneath the graphic layers.. I tried to move the tiled layer around to get up top. No success. Any idea?
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>GraphicsParcel<SPAN class="punctuation token">,</SPAN> GraphicsBuffer<SPAN class="punctuation token">,</SPAN> clusterLayer<SPAN class="punctuation token">,</SPAN> tiledMapServiceLayer<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
