We have several dock panes that use Observable Collections of layers, which we initialize when the ribbon button is clicked (i.e., on the main thread). In the Module class, we subscribe to the LayersAdded event, process the event, then fire our own event that the dock panes listen to and update their collections. In 2.5 this worked fine, but in 2.6 the LayersAdded event is now being fired from the CIM thread instead of the main thread, which has caused our dock panes to crash when updating the collections. Interestingly, the LayersRemoved event is still fired from the main thread. Is this an intentional design? I haven't found anything in the release notes or other documentation.
In case anyone else is dealing with this, I found this workaround in the Community Samples:
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">onLayersAddRem</SPAN><SPAN class="punctuation token">(</SPAN>LayerEventsArgs obj<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Instead of:</SPAN>
<SPAN class="token function">PopulateSnapList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// This will crash now</SPAN>
<SPAN class="comment token">//Run on UI Thread to sync layersadded event (which runs on background)</SPAN>
System<SPAN class="punctuation token">.</SPAN>Windows<SPAN class="punctuation token">.</SPAN>Application<SPAN class="punctuation token">.</SPAN>Current<SPAN class="punctuation token">.</SPAN>Dispatcher<SPAN class="punctuation token">.</SPAN><SPAN class="token function">BeginInvoke</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>Action<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">PopulateSnapList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
