Hi,I am new to this Arcgis javascript API. function projectToWebMercator(evt) { map.graphics.clear(); var point = evt.mapPoint; var symbol = new esri.symbol.SimpleMarkerSymbol().setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_DIAMOND); var graphic = new esri.Graphic(point, symbol); var outSR = new esri.SpatialReference({ wkid: 102113}); map.graphics.add(graphic); alert("Before method"); gsvc.project([ graphic ], outSR, function(features) { alert("inside method"); pt = features[0].geometry; graphic.setInfoTemplate(new esri.InfoTemplate("Coordinates", "<p> X: " + pt.x + "<br/> Y: " + pt.y + "</p>" + "<input type='button' value='Convert back to LatLong' onclick='projectToLatLong();' />" + "<div id='latlong'></div>")); map.infoWindow .setTitle(graphic.getTitle()) .setContent(graphic.getContent()) .show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint)); }); }In the above code, gsvc.project([ graphic ], outSR, function(features) method does not run. I get the "Before method"-alert. But I don't get "inside method"-alert. Please do help me in resolving the issue. What could be the possible solution?PS: I have declared gsvc as a global variable and defined it inside a init() function likegsvc = new esri.tasks.GeometryService("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");ThanksPrasanna
