When I go to the web app builder to create an app, I can't add widgets or do anything because the OK and Cancel buttons of any pop up window in the appbuilder don't work.
Michael Souffront,
Can you please give us more information to help you out better? What version are you working with? AGOL, Portal or Developer?
-Stan
The AGOL version.
Try clearing your browser cache.
16 Ways to Clear Your Browser's Cache - wikiHow
Does this happen in all browsers or just a few?
Michael Souffront
Everything seems to be working just fine on my end for the OK and Cancel buttons. Have you tried to clear your browser cache? This might be a browser problem. I am using Firefox and Chrome and no problems here.
It is now working, I didn't do anything today though.
I did clear my cache and restarted my computer last week and that didn't work then.
Anyway, thanks for your responses.
Michael
Same issue as Michael.
WAB 1.0 Dev Edition freshly installed from Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers (today)
The locale is French. Cache cleared. Server stopped/started after the first time the issue happened, just in case.
All starts fine until the welcome page. I hit "create" and fill in the fields. Neither OK nor Cancel do cause any action, apart of the whole dialog box getting surrounded by a blue rim. The dialog box can be closed with the cross icon in the top right corner. I observe the same behaviour in the "import" dialog box : OK and Cancel have no effect whatsoever.
NOTE : issue seems to be Chrome only.
Regards,
Matt
Matt,
I don't have a solution for you I just want to clarify for other users.
exactly the same issue as Matt,
Chrome version : 41.0.2272.89 m
No issues in Firefox. So I have switched to Firefox. However I would like to know the reason behind it.
Firefox version: 36.0.1
Hello Stan.
Issue repeated this morning with Chrome 41.0.2272.89 m
No problem with IE 11.0.9600.17691 and Firefox 32.0.3
All running on Windows 7.
Regards.
All,
Strange I just tested this morning using Chrome Version 41.0.2272.89 m and created a new app without any issue. Have any of you tried to open your browsers developer tools and see what the web console says?
I have had no problem with Chrome 41.0.2272.89m either. Well I guess we can at least rule that out as the issue.
Yes I've checked the console. And unfortunately there is absolutely nothing to see there. Given that the issue has only been seen on Chrome so far, I wouldn't rule out a browser-related cause. But for sure it won't be enough, there'll be a state that the browser needs to be put in in as well...
Mathias,
Very Strange. Can you go into Chrome Developer tools Settings (the little gear icon in the upper right) and make sure Disable cache (while DevTools is open) is checked and try reloading the WAB site again with devtools open?
I confirm. 🙂 Cache disabled in dev tools settings, dev tools left open, WAB page reloaded, trying to create an app, OK/Cancel do NOT respond to clicks.
Issue persisting after a fresh install of WAB 1.1.
Will go for tech support indeed.
Does your monitor support both touch screen and mouse click? We are able to reproduce the problem on OK button with mouse clicks on touch screen monitor.
Jianxia
Hello Jianxia. Indeed, I have a mouse+touch laptop.Outside of the WAB, I've myself encoutered spurious issues while developping bare Dojo apps, that I traced back to the dojo/touch module ; in my case it was a weird shifting focus.
we found that It's a bug, we'll fix it in the coming release.
Los miembros registrados pueden publicar, seguir actualizaciones y más. ¿Nuevo aquí? Regístrate gratis.
