Struggling with "best" Map Algebra syntax to use in scripts via PythonWin (NOT the Python window in ArcGIS, which seems to allow for different syntax - which is confussingm, but off topic)...Anyway... Classic "make streams from flow accumulation" scenario...In v9.3 I could do this:flowAccGrd = "flow_acc" flowDirGrd = "flow_dir" somaExp = "streamlink(con(" + flowAccGrd + " > 500, 1, setnull(1)), " + flowDirGrd + ")" streamLinkGrd = "stream_link" gp.SingleOutputMapAlgeba_sa(somaExp, streamLinkGrd)Solid...Now as I try to rewrite some stuff in the new v10 syntax, the best I can com up with is this:flowAccGrd = "flow_acc" flowDirGrd = "flow_dir" streamLinkTmp = arcpy.sa.StreamLink(arcpy.sa.Con(flowAccGrd, 1, arcpy.sa.SetNull(1,1), "VALUE >= 500")), flowDirGrd) streamLinkGrd = "stream_link" streamLinkTmp.save(streamLinkGrd)
Is there a better/more compact way to write this expresion ini v10 sytax (again, writting for a "stand-alone script")?Is that imbedded arcpy.sa.SetNull(1,1) neccessary - or is there a more elegant way to use the IsNull() and SetNull() expressions inside of a con() statement... Seemed easier in v9.3.
