I got an SystemError : error return without exception set error when trying to write a unicode into a blob field into a table inside a FGDB using arcpy.da.UpdateCursor with ArcGIS v10.3
for instance:
<SPAN class="keyword token">import</SPAN> arcpy
value <SPAN class="operator token">=</SPAN> u<SPAN class="string token">"a unicode string! with some accent éàèû"</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"c:\\my_fgdb.fgdb\my_table"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"blob_field"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> where_clause<SPAN class="operator token">=</SPAN>"FID <SPAN class="operator token">=</SPAN> <SPAN class="string token">'0'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> value
cursor<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I know blob can store string, but is it normal it cannot store unicode?
