Hello everyone,
I've migrated a VB script that uses ArcObjects to a C++ Win32 DLL (using Visual Studio 2013).
And now I would like to test my DLL by launching it from my ArcMap 10.3 installation.
The problem is that when I try to add it through "Customize -> Customize Mode -> Add from file" it does not succeed and raise the following message: "Can't load type library from specified file", even when I run ArcMap as Administrator.
The same way, the "ESRIRegAsm.exe" I tried to use in command line also refuses to register my DLL.
I've made research but I could not find any answer to make it work.
But maybe I am not doing this the right way. Do I need to implement a COM component to add my DLL to ArcMap ?
Anything that would help is welcome.
Thanks in advance.
