Summary:
My PopupTemplate JavaScript promise for the contents is never being executed.
My Requirements:
I am attempting to code a feature that will allow the user to click on a graphic in a Feature Layer and see a popup. We have integrated the map into our ASP.Net MVC web application using the JavaScript 4.5 API.
I have coded the popup in JavaScript as a Popup Template. When the user clicks on a graphic (that will represent a map pin-point), I need the code to do an (asynchronous) AJAX HTTP GET to an endpoint in order to retrieve a JSON object. The object will contain some data that will be displayed in the popup.
I have assigned the 'content' property of my PopupTemplate to my JavaScript function that returns a promise.
My Problem:
It appears that the promise is never being executed, as breakpoints in my code within the promise are never hit.
I have tried several ways to code the promise with no success. I am using esriRequest to actually do the AJAX GET, and returning the promise from this as the function assignment. Please see my attached code.
I think the JavaScript API is just executing my function and ignoring the promise that I am returning.
