I am having trouble getting the code below to execute succesfully:import arcpy tableList = ['Database Connections\\Metering_Data.odc\\tblFlowMeters', \ 'Database Connections\\Metering_Data.odc\\tblDataCollectionPeriods', \ 'Database Connections\\Metering_Data.odc\\tblFlowMeterDataCollectionPeriods', \ 'Database Connections\\Metering_Data.odc\\tblMeteringData'] fieldList = [['tblFlowMeters.MeterName'], ['tblDataCollectionPeriods.StartDate', \ 'tblDataCollectionPeriods.EndDate'], ['tblMeteringData.MeteringDataId', \ 'tblMeteringData.MeteringDateTime', 'tblMeteringData.DepthInches', \ 'tblMeteringData.VelocityFTperSec', 'tblMeteringData.FlowMGD', \ 'tblMeteringData.RainInches','tblMeteringData.DebrisInches']] whereClause = "(tblFlowMeters.FlowMeterId = tblFlowMeterDataCollectionPeriods.FlowMeterId \ AND tblFlowMeterDataCollectionPeriods.DataCollectionPeriodsId = \ tblDataCollectionPeriods.DataCollectionPeriodsId AND \ tblDataCollectionPeriods.DataCollectionPeriodsId = \ tblMeteringData.DataCollectionPeriodId AND \ tblFlowMeterDataCollectionPeriods.FlowMeterIdDataCollectionPeriodsId \ = tblMeteringData.FlowMeterDataCollectionPeriodsId ) AND \ (tblFlowMeters.MeterName = 'RH2A')" arcpy.MakeQueryTable_management(tableList, "tblFlowMetersTest7", "USE_KEY_FIELDS", "tblMeteringData.MeteringDataId", fieldList, whereClause)
I get the following error message when I run it:Traceback (most recent call last): File "<string>", line 73, in execInThread File "C:\Program Files\PyScripter\Lib\rpyc.zip\rpyc\core\netref.py", line 196, in __call__ File "C:\Program Files\PyScripter\Lib\rpyc.zip\rpyc\core\netref.py", line 71, in syncreq File "C:\Program Files\PyScripter\Lib\rpyc.zip\rpyc\core\protocol.py", line 431, in sync_request File "C:\Program Files\PyScripter\Lib\rpyc.zip\rpyc\core\protocol.py", line 379, in serve File "C:\Program Files\PyScripter\Lib\rpyc.zip\rpyc\core\protocol.py", line 337, in _recv File "C:\Program Files\PyScripter\Lib\rpyc.zip\rpyc\core\channel.py", line 50, in recv File "C:\Program Files\PyScripter\Lib\rpyc.zip\rpyc\core\stream.py", line 166, in read EOFError: [Errno 10054] An existing connection was forcibly closed by the remote host
If I run the code without the fieldList variable, the code runs succesfully. Is there something wrong with my fieldList variable that I am not seeing?I can run the MakeQueryTable_managment toolbox in ArcMap with all the same values successfully. It also runs if I do it via a model. When I export the model to a script it also runs successfully.Anyone have an idea why my fieldList variable wont' allow it to run?
