hi all,I'm just starting out in scripting and appreicate any help that I can get with this. I am trying to build a simple tool that will take text from two text boxes, enter them into an SQL query and hence select attributes from a "Cadastre - Parcels" Layer in my .mxdThe code I've written so far is this: Private Sub GoButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles GoButton.Click
Dim pMXDoc As ESRI.ArcGIS.ArcMapUI.IMxDocument
pMXDoc = My.ArcMap.Document
Dim pMap As ESRI.ArcGIS.Carto.IMap
pMap = pMXDoc.FocusMap
Dim pFeatureLayer As ESRI.ArcGIS.Carto.IFeatureLayer
Dim pActiveView As ESRI.ArcGIS.Carto.IActiveView
pActiveView = pMap
Dim pFeatureSelection As ESRI.ArcGIS.Carto.IFeatureSelection
Dim LayerName As String
LayerName = "Cadastre - Parcels"
For i = 0 To pMap.LayerCount - 1
If UCase(pMap.Layer(i).Name.Trim()) = UCase(LayerName.Trim()) Then
pFeatureLayer = pMap.Layer(i)
Exit For
End If
'Get attributes from the textboxes
Dim AttPlanNumber As String
Dim AttLotNumber As String
Dim SearchStatement As String
AttPlanNumber = txtDPNumber.Text
AttLotNumber = txtLotNumber.Text
pFeatureSelection = pFeatureLayer
Dim filter As New ESRI.ArcGIS.Geodatabase.QueryFilterClass()
SearchStatement = "PLANNO = '" & AttPlanNumber & "' & LOTNO = '" & AttLotNumber & "'"
filter.WhereClause = SearchStatement
pActiveView.PartialRefresh(ESRI.ArcGIS.Carto.esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)
pFeatureSelection.SelectFeatures(filter, ESRI.ArcGIS.Carto.esriSelectionResultEnum.esriSelectionResultNew, False)
End Sub
unfortunately, when I run the tool I get this: pFeatureSelection.SelectFeatures(filter, ESRI.ArcGIS.Carto.esriSelectionResultEnum.esriSelectionResultNew, False) -----Check the ErrorCode property of the exception to determine the HRESULT returned by the COM Object.Where am I going wrong?Thanks,Lauren
