I modified my code based on an example to set the extent, but it appears not to be working. Here is my code:
<!DOCTYPE html>
<html>
<head>
<title>Create a Map</title>
<meta http-equiv="content-type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
<style>
html, body, #mapDiv
padding:0;
margin:0;
height:100%;
</style>
<script src="http://js.arcgis.com/3.11/"></script>
<script>
var map;
require(["esri/map", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/ArcGISDynamicMapServiceLayer",
"dojo/dom", "dojo/on", "dojo/parser", "esri/geometry/Extent", "dojo/domReady!"], function (Map, Tiled, ArcGISDynamicMapServiceLayer, dom, on, parser, Extent
map = new Map("mapDiv", {
showAttribution: false,
sliderStyle: "large"
// add imagery
var tiled = new Tiled("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
map.addLayer(tiled);
// set operational layers
var baseLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Base/MapServer");
var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
// add operational layers
map.addLayer(baseLayer);
map.addLayer(operationalLayer);
// set map extent
var extent = new Extent();
extent.xmin = 777229.03;
extent.ymin = 1133467.92;
extent.xmax = 848340.14;
extent.ymax = 1185634.58;
map.setExtent(extent);
</script>
</head>
<body class="soria">
<div id="mapDiv">
</div>
</body>
</html>
