Morning all, this is a followup post to the thread I have going herehttp://forums.arcgis.com/threads/65282-confusion-with-ListDataFrames-and-ListlayersI'm still having a tough time understanding the ListDataFrames functionality and results. In my mind what I think ListDataFrames would give me is exactly that, a listing of data frames with the mxd. However when I execute this command I get back a listing of layers. All the examples I see in the help use [0] such as df = arcpy.mapping.ListDataFrames(mxd, "Transportation")[0]When I execute a line such as the above I get back a list of layers within my first layergroup. This is probably just me not understanding python or coding very well, it's driving me a little nuts. The objective of my script below is to save a layer of base_data from the current mxd to disk. Then look at the target mxd and see if it has a layer names Base_Data, if so remove it, then import the previously saved layer and add to the bottom of the target mxd. Then of course save.import arcpy from arcpy import env # Set overwrite option arcpy.env.overwriteOutput = True # Gather user input parameters TargetFile = arcpy.GetParameterAsText(0) if TargetFile > "": arcpy.AddMessage("Target File is True") # from current open mxd, save base data layer file to disk LayerFile = "./Base_Layer" arcpy.SaveToLayerFile_management("Base_Data_Group",LayerFile,"RELATIVE") arcpy.AddMessage("Base Data Saved as "+ LayerFile) mxd = arcpy.mapping.MapDocument(TargetFile) df = arcpy.mapping.ListDataFrames(mxd) lyr_list = arcpy.mapping.ListLayers(mxd) for lyr in lyr_list: if 'Base_Data' in lyr.name: arcpy.mapping.RemoveLayer(df,lyr) arcpy.AddMessage(lyr) path = LayerFile + '.lyr' arcpy.AddMessage("adding layer") addLayer = arcpy.mapping.Layer(path) arcpy.mapping.AddLayer(df, addLayer, "BOTTOM") TargetFile.arcpy.save()
