Would you help me?
What I need :
- when i click radio3 , then it show 2 routes with a different colours and each route have their infoTemplate
This is my Code
var jalanLayer = new esri.layers.GraphicsLayer({ id: "jalan" });
map.addLayer(jalanLayer);
//setup the route parameters
routeParams = new RouteParameters();
routeParams.stops = new FeatureSet();
routeParams.outSpatialReference = {
"wkid" : 102100
routeTask.on("solve-complete", showRoute);
routeTask.on("error", errorHandler);
//define the symbology used to display the route
stopSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CROSS).setSize(15);
stopSymbol.outline.setWidth(4);
routeSymbol = new SimpleLineSymbol().setColor(new dojo.Color([0, 0, 255, 0.5])).setWidth(5);
//Adds a graphic when the user clicks the map. If 2 or more points exist, route is solved.
function addStop() {
$("#loader").show();
var gl = map.getLayer("jalan");
gl.clear();
var stop1 = new esri.Graphic(
new esri.geometry.Point(longSt, latSt), stopSymbol);
stop1.attributes = new Object();
stop1.attributes.Name = "A";
var stop2 = new esri.Graphic(
new esri.geometry.Point(longEnd, latEnd ), stopSymbol);
stop2.attributes = new Object();
stop2.attributes.Name = "B";
routeParams.stops.features.push(stop1);
routeParams.stops.features.push(stop2);
if (routeParams.stops.features.length >= 2) {
routeTask.solve(routeParams);
lastStop = routeParams.stops.features.splice(0, 1)[0];
map.centerAndZoom(new esri.geometry.Point(longSt, latSt),12);
//Adds the solved route to the map as a graphic
function showRoute(evt) {
jalanLayer.add(evt.result.routeResults[0].route.setSymbol(routeSymbol));
$("#loader").hide();
// Wire UI Events
$("#radio3").on("click", function() {
longSt='106.9935517';
latSt='-6.2337483';
longEnd='106.994956';
latEnd='-6.2592437';
addStop();
routeSymbol = new SimpleLineSymbol().setColor(new dojo.Color([0, 255, 255, 0.5])).setWidth(5);
longSt = '106.9705696';
latSt = '-6.1916444';
longEnd = '106.9738868';
latEnd = '-6.219634';
addStop();
