Hi
I'm struggling to find a consistent behaviour on addresses in Ireland.
Note I use Esri Maps for Dynamics CRM version 1.0.1.0 on Dynamics CRM 2011.
Most likely the problem is me, but here are some questions :
- Would it be possible to see why a locate workflow status end up as 'cancelled'?
- The geocoding of the same single line address succeeds when submitted via the desktop ArcMap >> Find >> Locations >> "World Geocode Service (ArcGIS online)", but fail in CRM when used as a single line submission against a locate workflow. Should I expect the same result or is this behaviour correct/possible?
- One can select a country for the workflow - and it seems to affect the accuracy of my results. Unfortunate I can't find this in the design/edit interface of previously created workflows. So it is difficult to confirm if correct. Are this available/visible in the GUI?
- In the design/edit interface of previously created workflows, the "Esri Maps:Find Location" activity's properties >> address template >> Data Type is "Single Line Of Text", even if the workflow created with "these columns" and NOT "One Column". Would this affect the geocode result if the workflow was created as 'multi-attribute', but a user enter all information in a single attribute and leave the other attributes empty?
- Last question (for now) - Are there more detailed documentation available than what one can find here: Spatially enable your data—Esri Maps for Dynamics CRM | ArcGIS
