Hi all!
I'm trying to create and publish a vector tile service to AGOL.
On AGOL I use a basemap which has a quite unique tiling scheme and level of details. See here for more details.
My goal is to use the vector tile layer with this basemap.
The tiling scheme I created looks like this:
<SPAN class="prolog token"><?xml version="1.0" encoding="utf-8"?></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileCacheInfo</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>typens:TileCacheInfo<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>xsi</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://www.w3.org/2001/XMLSchema-instance<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>xs</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://www.w3.org/2001/XMLSchema<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>typens</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://www.esri.com/schemas/ArcGIS/2.3.0<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>SpatialReference</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>typens:ProjectedCoordinateSystem<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>WKT</SPAN><SPAN class="punctuation token">></SPAN></SPAN>PROJCS["NZGD_2000_New_Zealand_Transverse_Mercator",GEOGCS["GCS_NZGD_2000",DATUM["D_NZGD_2000",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",1600000.0],PARAMETER["False_Northing",10000000.0],PARAMETER["Central_Meridian",173.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0],AUTHORITY["EPSG",2193]]<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>WKT</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>XOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-4020900<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>XOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>YOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1900<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>YOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>XYScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>10000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>XYScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ZOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-100000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ZOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ZScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>10000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ZScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-100000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>10000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>XYTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.001<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>XYTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ZTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.001<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ZTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.001<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>HighPrecision</SPAN><SPAN class="punctuation token">></SPAN></SPAN>true<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>HighPrecision</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>WKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2193<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>WKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LatestWKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2193<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LatestWKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>SpatialReference</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileOrigin</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>typens:PointN<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>X</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-8397963.942936342<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>X</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Y</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1.9997963942936342E7<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Y</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileCols</SPAN><SPAN class="punctuation token">></SPAN></SPAN>512<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileCols</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileRows</SPAN><SPAN class="punctuation token">></SPAN></SPAN>512<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileRows</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>DPI</SPAN><SPAN class="punctuation token">></SPAN></SPAN>96<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>DPI</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LODInfos</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>typens:ArrayOfLODInfo<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LODInfo</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>typens:LODInfo<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4096000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1083.7355008043351<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LODInfo</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2048000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>541.86775040216753<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1024000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>270.93387520108377<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>3<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>512000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>135.46693760054188<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>256000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>67.733468800270941<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>5<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>128000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>33.866734400135471<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>6<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>64000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>16.933367200067735<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>7<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>32000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>8.4666836000338677<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>8<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>16000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4.2333418000169338<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>9<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>8000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2.1166709000084669<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>10<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1.0583354500042335<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>11<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.52916772500211673<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>12<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.26458386250105836<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>13<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>500<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.13229193125052918<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>14<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>250<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.066145965625264591<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LODInfos</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>PreciseDPI</SPAN><SPAN class="punctuation token">></SPAN></SPAN>96<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>PreciseDPI</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileCacheInfo</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>There aren't any error messages, however, the published seems to be empty. The web map zooms to the right extent, but nothing gets displayed.
Does anyone know what's going on?
