Hi,I have text box in standalone application windows form application(ImapDocument) for parcel No when user click on Search the listview populated with the Parcel Info.it work fine, I am using ImapDocument.I need to zoom to this parcel in page layout and export to PDF or jpg when user click on Create Map/Print Button. I can't figure out how to do that.I am using ArcgisDesktop 10.1here is my code so far.Private Sub btnSearch_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnSearch.Click License = New esriLicenseObj License.Initialize_ArcInfo() Try 'strPath = "C:\Users\owner\Desktop\gis Dev\parcel.mxd" ' MXD path Dim pMapdoc as ImapDocument = New MapDocument pMapDoc.Open("C:\Users\owner\Desktop\gis Dev\parcel.mxd") 'pActiveView = pMapDocument.PageLayout 'pActiveView.Activate(hWnd) Dim pFeatureLayer As IFeatureLayer = CType(pMapDoc.Layer(0, 0), IFeatureLayer) Dim featureName As String = pFeatureLayer.Name Dim pMap As IMap ''Dim pLayer As ILayer Dim pActiveView As IActiveView pActiveView = pMapDoc.PageLayout pActiveView.Activate(GetDesktopWindow()) '(hWnd) 'Dim pFeatureLayer As IFeatureLayer Dim pFeatureSelection As IFeatureSelection Dim pQueryFilter As IQueryFilter pMap = pMapDoc.Map(0) ' this is the solution pActiveView = pMap pQueryFilter = New QueryFilter ''First layer in the map 'If Not TypeOf pMap.Layer(0) Is IFeatureLayer Then Exit Sub pFeatureLayer = pMap.Layer(0) pFeatureSelection = pFeatureLayer 'QI 'Create the query filter pQueryFilter = New QueryFilter 'pQueryFilter.SubFields = "PROP_ID" pQueryFilter.WhereClause = "PROP_ID = '" & UCase(txtParcel.Text) & "'" Dim pFClass As IFeatureClass = pFeatureLayer.FeatureClass Dim pFCursor As IFeatureCursor = pFClass.Search(pQueryFilter, True) 'Invalidate only the selection cache 'Flag the original selection pActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing) 'Perform the selection pFeatureSelection.SelectFeatures(pQueryFilter, esriSelectionResultEnum.esriSelectionResultNew, False) 'Flag the new selection pActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing) Dim pFeature As IFeature pFeature = pFCursor.NextFeature Dim nCols As Integer nCols = pFeature.Fields.FieldCount 'define row 'Dim nRows As Integer ''Me.Listsheet.ColumnHeaderCollection = nCols 'nRows = pFeature.Fields.FieldCount For i = 2 To nCols - 1 ' Me.lstResult.Items.Add(pFeature.Fields.Field(i).Name & " " & pFeature.Value(i)) Me.Listsheet.Items.Add(pFeature.Fields.Field(i).Name & " " & pFeature.Value(i)) 'Me.tmpDT.DataSource(pFeature.Fields.Field(i).Name & " " & pFeature.Value(i)) 'convertICursorToDataTable(tmpDT) Next ''Do not make any call to ArcObjects after ShutDownApplication() ' Get the license back to the ArcInfo ' License.ShutDown() ''**************************************************************** Catch ex As Exception MsgBox(ex.ToString) Return End Try '****************************************************************************** End Sub[ATTACH=CONFIG]23487[/ATTACH]Thank you
