Has anyone had any luck getting ESRI to fix the token timeout issue with OpsDashboard and IWA/Portal? I opened a ticket back in August and have yet to get a resolution.
Environemnt:
Portal 10.7.1, IWA auth, Operations Dashboard web client.
Behavior:
Initially SSO works and the dashboard comes up, after exactly 30 minutes the token expires and the app prompts for auth. If i signin, it prompts multiple times for sign in and eventually lets you through.
I have been able to temporarily "fix" the issue by added a meta refresh tag at 25 minutes into the Ops Dashboard HTML.
My original Bug number was #BUG-000124152 which was marked as "Not in Current Product Plan" in early December. In the case it mentioned that i was actually experiencing #BUG-000127276, which BTW was resolved in 10.7?
I am still experiencing the issue but have reopened the case. This seems very similar to the token timeout that WAB was seeing in 10.6/10.6.1 which was resolved in 10.7. It would be great if someone from ESRI would reach out to atleast a few people affected by these bugs and ask if it was resolved.
The original thread where this was first mentioned was here https://community.esri.com/message/897492-re-wab-token-expiration .
