I'm having some issues getting a geoprocessing task to run with a polygon entered by the user.
The GP task works in ArcMap, and also from WebApp Builder - but in order for this to fit my wider workflow I would much rather do this with JS API 4.x.
Currently, I'm receiving an Error 500: Error performing execution operation. It's an error in my code, though I'm not sure where I'm getting tripped up.
The GP task expects a few input parameters, listed below. I'm only feeding it the first as I believe the last couple can be null (I hope).
As a side note it would be lovely to see ESRI put up at least one example of accepting polygon input into a simple GP task. Almost every single example is done with an input of type point, and that makes it hard for those of us trying to learn since there's no mention of featuresets, etc. Only recently have I found an example with a polyline, but it was something different again. When there's 3 possible geometry types, and they each need to be treated differently, it would be nice to see an example of each, because at the moment there's only 1/3 of the examples.
<SPAN class="comment token">//Define the GP service location</SPAN>
<SPAN class="keyword token">var</SPAN> gpService <SPAN class="operator token">=</SPAN> L<SPAN class="punctuation token">.</SPAN>esri<SPAN class="punctuation token">.</SPAN>GP<SPAN class="punctuation token">.</SPAN><SPAN class="token function">service</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"http://machine:6080/arcgis/rest/services/GPServices/TestPolygonGPService/GPServer/Test%20Polygon%20GP%20Service"</SPAN><SPAN class="punctuation token">,</SPAN>
useCors<SPAN class="punctuation token">:</SPAN><SPAN class="keyword token">true</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Trigger when the create event is complete</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>L<SPAN class="punctuation token">.</SPAN>Draw<SPAN class="punctuation token">.</SPAN>Event<SPAN class="punctuation token">.</SPAN>CREATED<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> layer <SPAN class="operator token">=</SPAN> event<SPAN class="punctuation token">.</SPAN>layer<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> gpTask <SPAN class="operator token">=</SPAN> gpService<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
gpTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setParam</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"InputPolygonSymbology_lyr"</SPAN><SPAN class="punctuation token">,</SPAN> layer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toGeoJSON</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toGeoJSON</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"setParameter of event.layer successful"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
gpTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">run</SPAN><SPAN class="punctuation token">(</SPAN>polyQueryCallback<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"successfully called and returned the callback"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
drawnItems<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">polyQueryCallback</SPAN><SPAN class="punctuation token">(</SPAN>error<SPAN class="punctuation token">,</SPAN> response<SPAN class="punctuation token">,</SPAN> raw<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//map.addLayer(L.geoJSON(layer));</SPAN>
<SPAN class="comment token">//console.log(Polyarea);</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Geoprocessing Task Looks Like:
<SPAN class="token constant">Task</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token constant">Test</SPAN> <SPAN class="token constant">Polygon</SPAN> <SPAN class="token constant">GP</SPAN> <SPAN class="token constant">Service</SPAN>
<SPAN class="token constant">Display</SPAN> <SPAN class="token constant">Name</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token constant">Test</SPAN> <SPAN class="token constant">Polygon</SPAN> <SPAN class="token constant">GP</SPAN> <SPAN class="token constant">Service</SPAN>
<SPAN class="token constant">Description</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token constant">This</SPAN> service is designed to test returning a single unique identifying parameter<SPAN class="punctuation token">,</SPAN> together with comitting a polygon to an <SPAN class="token constant">SDE</SPAN> database table whilst using in_memory workspaces<SPAN class="punctuation token">.</SPAN>
<SPAN class="token constant">Category</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="token constant">Help</SPAN> <SPAN class="token constant">URL</SPAN><SPAN class="punctuation token">:</SPAN> http<SPAN class="punctuation token">:</SPAN><SPAN class="operator token">/</SPAN><SPAN class="operator token">/</SPAN>mi018461<SPAN class="punctuation token">:</SPAN><SPAN class="number token">6080</SPAN><SPAN class="operator token">/</SPAN>arcgis<SPAN class="operator token">/</SPAN>rest<SPAN class="operator token">/</SPAN>directories<SPAN class="operator token">/</SPAN>arcgisoutput<SPAN class="operator token">/</SPAN><SPAN class="token constant">GPServices</SPAN><SPAN class="operator token">/</SPAN><SPAN class="token constant">TestPolygonGPService_GPServer</SPAN><SPAN class="operator token">/</SPAN><SPAN class="token constant">GPServices_TestPolygonGPService</SPAN><SPAN class="operator token">/</SPAN><SPAN class="token constant">Model</SPAN><SPAN class="punctuation token">.</SPAN>htm
<SPAN class="token constant">Execution</SPAN> <SPAN class="token constant">Type</SPAN><SPAN class="punctuation token">:</SPAN> esriExecutionTypeAsynchronous
<SPAN class="token constant">Parameters</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="token constant">Parameter</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token constant">InputPolygonSymbology_lyr</SPAN>
<SPAN class="token constant">Data</SPAN> <SPAN class="token constant">Type</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token constant">GPFeatureRecordSetLayer</SPAN>
<SPAN class="token constant">Display</SPAN> <SPAN class="token constant">Name</SPAN> <SPAN class="token constant">InputPolygonSymbology</SPAN><SPAN class="punctuation token">.</SPAN>lyr
<SPAN class="token constant">Description</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">50</SPAN> percent opacity<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">and</SPAN> purple<SPAN class="punctuation token">.</SPAN>
<SPAN class="token constant">Direction</SPAN><SPAN class="punctuation token">:</SPAN> esriGPParameterDirectionInput
<SPAN class="token constant">Default</SPAN> <SPAN class="token constant">Value</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="token constant">Geometry</SPAN> <SPAN class="token constant">Type</SPAN><SPAN class="punctuation token">:</SPAN> esriGeometryPolygon
<SPAN class="token constant">HasZ</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN>
<SPAN class="token constant">HasM</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN>
<SPAN class="token constant">Spatial</SPAN> <SPAN class="token constant">Reference</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">102100</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="number token">3857</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="token constant">Fields</SPAN><SPAN class="punctuation token">:</SPAN>
objectid <SPAN class="punctuation token">(</SPAN> type<SPAN class="punctuation token">:</SPAN> esriFieldTypeOID <SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">alias</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token constant">OBJECTID</SPAN> <SPAN class="punctuation token">)</SPAN>
rand <SPAN class="punctuation token">(</SPAN> type<SPAN class="punctuation token">:</SPAN> esriFieldTypeString <SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">alias</SPAN><SPAN class="punctuation token">:</SPAN> rand <SPAN class="punctuation token">,</SPAN> length<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">50</SPAN> <SPAN class="punctuation token">)</SPAN>
shape_Length <SPAN class="punctuation token">(</SPAN> type<SPAN class="punctuation token">:</SPAN> esriFieldTypeDouble <SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">alias</SPAN><SPAN class="punctuation token">:</SPAN> shape_Length <SPAN class="punctuation token">)</SPAN>
shape_Area <SPAN class="punctuation token">(</SPAN> type<SPAN class="punctuation token">:</SPAN> esriFieldTypeDouble <SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">alias</SPAN><SPAN class="punctuation token">:</SPAN> shape_Area <SPAN class="punctuation token">)</SPAN>
<SPAN class="token constant">Features</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># records: 1</SPAN>
objectid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN>
rand<SPAN class="punctuation token">:</SPAN> null
shape_Length<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">8686075.788202167</SPAN>
shape_Area<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4.50582047673178E12</SPAN>
<SPAN class="token constant">Polygon</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">9999054.1244</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2095332.1645000018</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">8234515.1612</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2524514.3561999984</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">8203558.337300001</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">139316.78449999914</SPAN><SPAN class="punctuation token">]</SPAN> more<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
<SPAN class="token constant">Parameter</SPAN> <SPAN class="token constant">Type</SPAN><SPAN class="punctuation token">:</SPAN> esriGPParameterTypeRequired
<SPAN class="token constant">Parameter</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token constant">RandVal</SPAN>
<SPAN class="token constant">Data</SPAN> <SPAN class="token constant">Type</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token constant">GPString</SPAN>
<SPAN class="token constant">Display</SPAN> <SPAN class="token constant">Name</SPAN> <SPAN class="token constant">RandVal</SPAN>
<SPAN class="token constant">Direction</SPAN><SPAN class="punctuation token">:</SPAN> esriGPParameterDirectionOutput
<SPAN class="token constant">Parameter</SPAN> <SPAN class="token constant">Type</SPAN><SPAN class="punctuation token">:</SPAN> esriGPParameterTypeDerived
<SPAN class="token constant">Category</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The console returns:
More console/network stuff, showing what parameters are currently being sent.
