We are trying to create a .tpk file from a tile cache folder using arcpy and arcgis 10.1. We created the tile cache in python using “arcpy.ManageTileCache_management” and this works great. arcpy.ManageTileCache_management produces a cache folder with the expected resolution level folders; ie, L00- L14. However, when we call ExportTileCache immediately after from the same python script and use the tile cache folder as the source we get the following error:
ERROR:root:ERROR 999999: Error executing function. The workspace is not connected. Failed to execute (ExportTileCache)
Sample code:
arcpy.ExportTileCache_management("C:\Users\test\AppData\Roaming\tpkgen\tpkgen_cache", “C:\Users\test\AppData\Roaming\tpkgen”, "tpkgen_result", "TILE_PACKAGE", "COMPACT", scales)
Where tpkgen_cache is the tile cache created using ManageTileCache.
As a side note we can run the ExportTilePackage from ArcToolBox using tpkgen_cache as the input it works fine and produces a .tpk file as expected.
Does anyone have insight into this?
Thanks.
