The Create Web Map from JSON example shows how to pass parameters from a configuration file to the map:
webmap.itemData ={
"operationalLayers":[{
"url":"http://server.arcgisonline.com/ArcGIS/rest/services/Specialty/Soil_Survey_Map/MapServer",
"visibility":true,
"opacity":0.75,
"title":"Soil Survey Map",
"itemId":"204d94c9b1374de9a21574c9efa31164"
var layers = response.itemInfo.itemData.operationalLayers;
All of these items are either text, numbers, or boolean. How can I pass an ArcGIS object via JSON? For example, I want to specify a symbol using the same syntax as above. How would I include this symbol in the JSON?
new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT,
new dojo.Color([255,0,0]), 2),new dojo.Color([255,255,0,0.25]));
If I include this in the JSON without quotation marks, it's marked as an error since the JSON file doesn't know what esri.symbol.SimpleFillSymbol means. If I quote it, ArcGIS doesn't recognise it as an object since it's now a string.Do I need to break it into the component parts (STYLE_SOLID, STYLE_DASHDOT, [255,0,0], [255,255,0,0.25]) then reassemble?Thanks for any tips,Steve
