I want to develop a small application that get coordinates from user as input and generate a list of it. then i want to show this as a polygon on the map.
I am unable to push the list to the polygon ring. Anybody can help please
I application is attached!
Muhammad,
Here is your code working
You can try this one..but its need to be more specific
Default Editor
Dear Avinash,
I cannot reach to source of your sample, can you share!
ArcGIS API for JavaScript Sandbox
Robert,
Thank you very much for your time. This was exactly what i need.. Thanks again!
Thank you Avinash, Robert did it for me...
Muhammed,
You might want to mark my reply as the correct answer instead of yours.
Ok done, that was a mistake
Dear Robert,
What if i want to use UTM projected coordinates to place graphics. I tried to change the spatialReference to { wkid: 32638 }. But it is not working..
It might be easy but i am new to custom development.. Any help!
It would look like this then:
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1, user-scalable=no"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Coordinate to Map<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #viewDiv <SPAN class="punctuation token">{</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fmaxcdn.bootstrapcdn.com%2Fbootstrap%2F3.3.6%2Fcss%2Fbootstrap.min.css" target="_blank">https://maxcdn.bootstrapcdn.com/bootstrap/3.3.6/css/bootstrap.min.css</A><SPAN>"</SPAN></SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fajax.googleapis.com%2Fajax%2Flibs%2Fjquery%2F3.1.1%2Fjquery.min.js" target="_blank">https://ajax.googleapis.com/ajax/libs/jquery/3.1.1/jquery.min.js</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.1%2Fesri%2Fcss%2Fmain.css" target="_blank">https://js.arcgis.com/4.1/esri/css/main.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.1%2F" target="_blank">https://js.arcgis.com/4.1/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fajax.googleapis.com%2Fajax%2Flibs%2Fjquery%2F1.12.4%2Fjquery.min.js" target="_blank">https://ajax.googleapis.com/ajax/libs/jquery/1.12.4/jquery.min.js</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN>########## Map ###########<SPAN class="operator token">--</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="keyword token">var</SPAN> app <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/SceneView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Popup"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Polygon"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/GeometryService"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/support/ProjectParameters"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/config"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> Map<SPAN class="punctuation token">,</SPAN> SceneView<SPAN class="punctuation token">,</SPAN> Popup<SPAN class="punctuation token">,</SPAN> Polygon<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol<SPAN class="punctuation token">,</SPAN> GeometryService<SPAN class="punctuation token">,</SPAN> ProjectParameters<SPAN class="punctuation token">,</SPAN> esriConfig<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> dom<SPAN class="punctuation token">,</SPAN> on <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"hybrid"</SPAN><SPAN class="punctuation token">,</SPAN> ground<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"world-elevation"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SceneView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">43.940626</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">26.346404</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">12</SPAN><SPAN class="punctuation token">,</SPAN> tilt<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">30</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> esriConfig<SPAN class="punctuation token">.</SPAN>geometryServiceUrl <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Futility.arcgisonline.com%2FArcGIS%2Frest%2Fservices%2FGeometry%2FGeometryServer" target="_blank">https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN>location <SPAN class="operator token">=</SPAN> event<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Displays the popup</SPAN> view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN>visible <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> polAtt <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> Name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Keystone Pipeline"</SPAN><SPAN class="punctuation token">,</SPAN> Owner<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"TransCanada"</SPAN><SPAN class="punctuation token">,</SPAN> Length<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"3,456 km"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/************************ * Create a polygon graphic ************************/</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">showPolygon</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// Create a polygon geometry</SPAN> <SPAN class="keyword token">var</SPAN> polygon <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Polygon</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> rings<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">43.935018</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">26.365905</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">43.958770</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">26.366693</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">43.961578</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">26.348339</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">43.933733</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">26.342883</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN>polygon<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toJSON</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Create a symbol for rendering the graphic</SPAN> <SPAN class="keyword token">var</SPAN> fillSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">227</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">139</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">79</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.8</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new SimpleLineSymbol()</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/******************************************* * Create a new graphic and add the geometry, ******************************************/</SPAN> <SPAN class="keyword token">var</SPAN> polygonGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> geometry<SPAN class="punctuation token">:</SPAN> polygon<SPAN class="punctuation token">,</SPAN> symbol<SPAN class="punctuation token">:</SPAN> fillSymbol<SPAN class="punctuation token">,</SPAN> attributes<SPAN class="punctuation token">:</SPAN> polAtt<SPAN class="punctuation token">,</SPAN> popupTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new PopupTemplate()</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"{Name}"</SPAN><SPAN class="punctuation token">,</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN> type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"fields"</SPAN><SPAN class="punctuation token">,</SPAN> fieldInfos<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN> fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Name"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Owner"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Length"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addMany</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>polygonGraphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">goTo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>polygonGraphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> app<SPAN class="punctuation token">.</SPAN>addUserPolygon <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>json<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN>json<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//return;</SPAN> view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeAll</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Create a symbol for rendering the graphic</SPAN> <SPAN class="keyword token">var</SPAN> fillSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">227</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">139</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">79</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.8</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new SimpleLineSymbol()</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// create the polygon and project it to the maps SR</SPAN> <SPAN class="keyword token">var</SPAN> poly <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Polygon</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> rings<SPAN class="punctuation token">:</SPAN> json<SPAN class="punctuation token">,</SPAN> spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">32638</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> params <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ProjectParameters</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> geomerties<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>poly<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> outSR<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">.</SPAN>spatialReference <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> geomSer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GeometryService</SPAN><SPAN class="punctuation token">(</SPAN>esriConfig<SPAN class="punctuation token">.</SPAN>geometryServiceUrl<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> geomSer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">project</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>geoms<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> polygonGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> geometry<SPAN class="punctuation token">:</SPAN> geoms<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> symbol<SPAN class="punctuation token">:</SPAN> fillSymbol<SPAN class="punctuation token">,</SPAN> attributes<SPAN class="punctuation token">:</SPAN> polAtt<SPAN class="punctuation token">,</SPAN> popupTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new PopupTemplate()</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"{Name}"</SPAN><SPAN class="punctuation token">,</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN> type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"fields"</SPAN><SPAN class="punctuation token">,</SPAN> fieldInfos<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN> fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Name"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Owner"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Length"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addMany</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>polygonGraphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">goTo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>polygonGraphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="comment token">// Add the graphics to the view's graphics layer</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"showBtn"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> showPolygon<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>h1 id<SPAN class="operator token">=</SPAN><SPAN class="string token">"heading"</SPAN><SPAN class="operator token">></SPAN>أحداثيات الى خريطة<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>h1<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>h4<SPAN class="operator token">></SPAN> Please Enter Geographic Coordinates Clockwise<SPAN class="operator token">!</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>h4<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>input type<SPAN class="operator token">=</SPAN><SPAN class="string token">"text"</SPAN> id<SPAN class="operator token">=</SPAN><SPAN class="string token">"coord"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>input type<SPAN class="operator token">=</SPAN><SPAN class="string token">'button'</SPAN> onclick<SPAN class="operator token">=</SPAN><SPAN class="string token">"changeText2(); clearCoord();"</SPAN> value<SPAN class="operator token">=</SPAN><SPAN class="string token">'Submit'</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>p<SPAN class="operator token">></SPAN>Coordinates List<SPAN class="punctuation token">:</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>p<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>ol id<SPAN class="operator token">=</SPAN><SPAN class="string token">"demo"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>ol<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>button id<SPAN class="operator token">=</SPAN><SPAN class="string token">"showBtn"</SPAN><SPAN class="operator token">></SPAN>Show Polygon on Map<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>button<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"listCoord.js"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I tried it but got the error "Cannot read property 'wkid' of undefined".
Los miembros registrados pueden publicar, seguir actualizaciones y más. ¿Nuevo aquí? Regístrate gratis.
